EBSpro - Программа для анализа спектра
Благодарил (а): 2141 раз
EBSpro_stable_setup_16.0.0.0.rar
EBSpro_stable_setup_16.0.0.1.exe
EBSpro_stable_setup_16.0.0.2.rar
EBSpro_stable_setup_17.0.0.0.rar
EBSpro_stable_setup_17.0.0.1.exe
Рекомендуемые устройства:
PCI-E
TBS 6983 PCIe Dual Tuner
TBS 6908 PCIe Quad Tuner
TBS 6925 PCIe Single Tuner
TBS 6905 PCIe Quad Tuner
USB
TBS 5927 USB Dual Tuner
TBS 5925 USB Single Tuner
TBS 5922 USB Single Tuner
TBS 5980 USB Single Tuner
Полная поддержка: (RFScan,BLScan,IQScan,SignalInfo feature)
STV091X
TBS 6983, 6903 Dual PCI-E, 6908,6905 Quad PCI-E
TBS 5927 USB2.0
STV090X
Omicom S2 PCI, Omicom S2 Pro PCI
TT S2-1600 PCI
Prof 7301 PCI, 7500 USB2.0, 8000 PCIE
TBS 6925 V1.x & 2.x PCI-E, 6926 PCI-E, QBox2(5920) USB2.0, QBox-CI(5980) USB2.0, 5925 USB2.0,
Technisat SkyStar2 eXpress HD PCI-E
NetUP Dual DVB-S2-CI PCI-E
KNC1 TV-Station DVB-S2 Twin PCI-E
BlackGold 3630, 3600, 3595
DVBWorld DW2104A,B USB2.0 – Only with CrazyBDA driver !
TMAX TAS210x
TT S2-4100 PCI-E
TBS 8922 PCI
TBS 5922(SE), 5990 USB2.0
TBS 6922(SE), 6928(SE), 6991(SE), 6982, 6985, 6902, 6904, 6910 PCI-E
STV0288
TBS 8910/Prof 6200/TeVii S420 PCI
TT S-1501 PCI
TBS QBox(5910) USB2.0, Prof 1100 USB2.0 – Only with CrazyBDA driver !
Zarlink ZL10313 (Intel CE6313)
Compro S300, S350 PCI
Avermedia A706 PCI
Avermedia A707 PCI-E
TeVii S630 – Only with CrazyBDA driver !
Частичная поддержка: (RFScan, IQScan, функция SignalInfo)
STB0899
TT S2-3200 PCI, S2-3600/3650 USB2.0.
Pinnacle PCTV 452e USB2.0.
TDA10086
TT S-1401 PCI, S-2400 USB2.0.
Technisat SkyStar USB2.0 Plus (TT S-2400 OEM).
Pinnacle PCTV 400e, 450e USB2.0.
Montage DS3000/2, DS3103
TeVii S464 PCI, 470/471 PCI-E, 660/662 USB2.0.
DVBSky S850/950/950CI/952 PCI-E, S860/960 USB2.0
TT S2-4600 USB2.0.
StarBlazer SB340 – Only with CrazyBDA driver !
VodzigorLans
Благодарил (а): 876 раз
16.0.0.1 (stable) [1 mar 2017]
- A fix to make it working again on Windows XP.
- Under certain circumstances EBSpro couldn't work as Pro version. Should work fine now.
Хорошая программа, много пользуюсь ей, на один клик быстрее CrazyScan :) Теперь EBSpro бесплатная без ограничений, что для меня хорошо.
П.С. Не мешало бы добавить скриншоты, ссылку на официальную страницу.
злой венгер
Непрочитанное сообщение злой венгер »
поосторожнее с exe -com там мина :cool:
Пользуюсь второй день, проблем не наблюдалось
milan58
Антенна(ы): Triax 110
Благодарил (а): 625 раз
злой венгер писал(а): 02 мар 2017, 21:21 поосторожнее с exe -com там мина :cool:
с этого сайта от программы http://ebspro.net/
злой венгер
wellikan писал(а): 02 мар 2017, 21:30 Пользуюсь второй день, проблем не наблюдалось
пользуюсь давно данной прогой, особенно прикольно ставим на андроид и
на крыше смартфоном крутим тарель :good: ..работает все четко
openfox
Благодарил (а): 164 раза
Непрочитанное сообщение openfox »
Привет всем , не поможете ли мне в этом головоломке, не знаю как лечить это везде "некрасивые" транспондеры (не знаю как и назвать :D )
как сделать чтоб они были как раньше ? карту поменял и вот поэтому новый EBSPro и вот такой результат - знаю не только у меня но может кто то победил ЭТО %)
TBS 6903 Proffesional
TBS 8922
IDLB-QUTL40-ULTRA-OPP
1.1 M motorized dish
Я так понимаю у вас профессиональная карта :good: которая показывает точную скорость потока, а более бюджетные модели карт видимо округляют каким то образом
Ванька
Непрочитанное сообщение Ванька »
скорее частота гетеродина сьехала.. %)
Причем здесь гетеродин? Если речь об символьной скорости (SR).
