Приём и обсуждение 18°W - Intelsat 37e в Ku диапазоне
- satesco
- Антенна(ы): 150cm
Intelsat 37e should also be added at 18.0W:
11179 V,11103,2/3,Dvb-S2,ACM,stream Packetized
12734 H,1200,5/6,Dvb-S2,ACM,Stream Generic.
- satesco
- Антенна(ы): 150cm
12731 H,1200,3/4,Dvb-S2/32APSK,ACM,GS,Single,
12730 H,260,1/2
12730 H,260,1/2
- VodzigorLans
- VodzigorLans
New range is activated. 10700-10950H What beam do you think? Какой луч, давайте узнаем!
New unknown peak 11450-11700V.
- satesco
- Антенна(ы): 150cm
10798 H is on a Multi-spot beam.The same configuration of beams as on Intelsat 33e at 60.0E.
- VodzigorLans
New one is 12706 V 31940 3/4 32APSK data
Most likely spot beam.
- VodzigorLans
- VodzigorLans
11121 V 5000 is left.
New is 11641 V 7500 1/2 ACM transport, multistream 21
nothing inside yet.
nothing inside yet.
- milan58
- Антенна(ы): Triax 110
12711,V,3181,12,QPSK-NTA
