- flie
- Ресивер: TBS5927
very impressive stephan94
here my test for :
25.8°E-10492_H-HAM radio payload-TBS5927&TBS5521-S2&S2X
https://www95.zippyshare.com/v/yIG60xJN/file.html
and sorry for all 32 feed reports and with both modes S2&S2X ,I know that all 32 Feed reports are not necessary but I only do it again for my self just to know the limit of TBS5521 (DVB-S2X) And exercise more so I can use IQmonitor in the best way ,and some time I can get transponder info using DVB-S2X-mode in Input=23 which can't be done in Tbs-6983-mode !
Added in 9 minutes 52 seconds:
No locked! ...it is the most important test for me
52.5°E-12168_H-8PSK-No locked-TBS5927&TBS5521_S2&S2X:
https://www25.zippyshare.com/v/MbyrNf4W/file.html
unfortunately TBS5521 can't get transponder info even using all 32 feed-reports or using Crazyscan-Blindscan2 !
SNR regarding LM is more stable in all 32 feed-reports using DVB-S2X-mode
- flie
- Ресивер: TBS5927
calibration for Inverto Black Ultra done I have stored all the necessary calibration
and yes there a different calibration for different Lnbs & cards
but this different always remain the same what ever satellite position we use or TBS-card used even lnbs only!...the difference between IBU & Televes ...remain always the same !
Successes
- flie
- Ресивер: TBS5927
final test for me "test limit " :
MORE THAN "NO-LOCKED" !
NS3/4& Unknown FEC&Modulation !
first thankx @Feedsat according to his final reports :these are
NS3/4!
11220_H,11262_V,11387_V,...CrasyScan can't see anything
https://www.satellitescommunity.de/thre ... #post32474
may be they are not active when I do these tests "feeds"!
11262 V 16APSK 32/45 with IQmonitor SR is around 34000ks/s always even if I have the correspond device ! the signal is (4.6-14.4+5.55=-4.3 Under LM )
I add also 11537_V_No locked_Unknown FEC&Modulation and it is the first time that I see different feed-report between Input=1&Input=32!
FEC&Modulation found only with IQmonitor 8PSK 8/9
Added in 12 minutes 7 seconds:
My Spectrum @ 10°E _11200_11550_HV
I will upload feed-report later -very bad internet here!
I will use IQmonitor 2.2.0.9 only for :
-feed-reports (showing Input point number is very useful )
-parser and screen shots for TransEdit
because:
-IQmonitor 2.2.0.9's BlindScan didn't work for me very well after calibration !
-also "Spectrum with STP=1" didn't work for me very well with "short Ku intervals"?! for example 11200_11550_HV or 12500_127500HV !
so I will IQmonitor 2.2.0.8 only for BlindScan
thank you very much STRANNIK
Best regards
flie.
NS3/4!
because:
Best regards
flie.
- flie
- Ресивер: TBS5927
feed reports loaded :
10°E-11220_H_NS3-4-TBS5927&TBS5521-S2&S2X:
https://www14.zippyshare.com/v/mXEwlciK/file.html
10°E-11262_V_NS3-4_TBS5927&TBS5521-S2&S2X:
https://www23.zippyshare.com/v/rNdGD0xb/file.html
10°E-11387_V_NS3-4_-TBS5927&TBS5521-S2&S2X:
https://www28.zippyshare.com/v/ccnnzOct/file.html
10°E-11537_V_No locked_Unknown FEC&Modulation_-TBS5927&TBS5521-S2&S2X:
https://www85.zippyshare.com/v/DbLJx6Xl/file.html
Сравнивал спектры, которые получены с шагом 100кГц.
Вначале полученный CrazyScan и IQmonitor с использованием функции RFscan
А затем программой IQmonitor без использования функции RFscan, которую некоторые (даже новейшие) карты не поддерживают
- flie
- Ресивер: TBS5927
HIGH- RESOLUTION- SPECTRA
with TBS-X... with such Exact result ! I Don't even mind if it takes a very long time !
Good luck
Good luck
Улучшил прорисовку групп низкоскоростных транспондеров и широкополосных транспондеров с частично пересекающимися полосами занимаемых частот.
Ниже один и тот же фрагмент спектра с шагом по частоте 74 и 50кГц:
- dreamsat
- Ресивер: TBS 6983, TBS6522
- Антенна(ы): 2,20m, 3,70m
Hello strannik,
this programm is better and better
My wish would still be a real-time spectrum. and a dB display in real time.
If I position my 3.7m antenna then I absolutely need it.
