Привет странник
Я только что провел то же исследование, что и вы, на 10 ° восточной долготы с версией 2303.
Результаты тоже очень хорошие.
Я, очевидно, лучше, чем вы, для приема и с большей антенной.
Я надеюсь, что это будет полезно для вас.
хороший день
Stephan94
хороший день
Stephan94
- flie
- Ресивер: TBS5927
very good result Stephan
I wanted to make Crazyscan works with TBS6903X but without success, I don't know how it works with Satesco & peon ?!
I think Strannik has made the right decision when making IQmonitor can work even with cards that don't support RF scanning
a simple test with N=180x2 was made in 21.6°E with both version IQmonitor 2.3.0.0 & 2.3.0.3 :
finally I discover that Feed-Report was always working in back , but I can't see it! because my PC resolution (1366x768) ! when I use an other resolution in an other PC (1280x960) I see Feed-Report in my screen corner ! so I pull it out ...sorry about that .
the only problem I Have now is "set-filers" is very slow when parser via Ts-file throw other programs like (TranEdit...VLC...etc) ,because I use a Hard disk USB 2.0 ! with wery low volume (only 16 GB!) ....I forget that transferring any files with USB 2.0 is very slow ! sorry about that one too
Added in 39 minutes 31 seconds:
I can use only IQmonitor so I don't know what are these transponders ? Generic-stream or Encapsulated ???
ACM/VCM ???
10730 V 45000 Qpsk2 4/5 MIS{1} ACM/VCM???
10918 V 45000 Qpsk2 4/5 MIS{1} ACM/VCM???
11109 V 1868 Qpsk2X 13/18 MIS{0} ACM/VCM???
Added in 46 minutes 49 seconds:
yes they are Transport-stream ACM/VCM MIS! can be found with TBS5521 too !
apparently TBS5521 multiply the number of GS-Transponders !!!
with TBS5927 the only not found is 11109 V 1868 Qpsk2X .
Already reported as Transport Multi-stream with IQmonitor-Feed report But I didn't read it !
ACM/VCM ???
- Peon
- Ресивер: TBS cards
@flie
CrazyScan 10216 was 4 versions. You must use the one from 7.11.2018 and others.
Последний раз редактировалось Peon 15 ноя 2019, 18:07, всего редактировалось 1 раз.
@flie
Очень хороший тест, я вас поздравляю!
В нём даже есть ответ на ваши вопросы:
Что касается "мультиплексирования" транспондеров, так это баг в CrazyScan - blindscan не может "отцепиться" от "сильного" транспондера.
В IQmonitor была аналогичная проблема (ведь используется один и тот же StreamReader уважаемого Crazycat`а)
Просто надо внимательно почитать полученную вами сводную таблицу транспондеров: ----> Таблица транспондеров
- Peon
strannik,
Спасибо за новую версию IQmonitor. Я с нетерпением жду тестирования.
У меня нет времени сейчас.
Надеюсь, что ваши проблемы будут успешно решены, время появится, и вы воспользуетесь IQmonitor 2304.
Здоровья и успехов!
Спасибо большое Strannik
хорошие выходные
Stephan
Added in 17 minutes 38 seconds:
Первые тесты убедительны.
идеальный результат.
хорошие выходные
Stephan
Added in 59 minutes 20 seconds:
Сегодня отключил RFScan при индикации частоты настройки.
Протестировал программу на Жар-птице - результат был получен за 3мин. 11 сек на вертикальной поляризации,
где транспондеры плотно заполняют весь диапазон, и за 3 мин.44 сек на горизонтальной поляризации,
где есть несколько "пропусков" между транспондерами
- dreamsat
- Ресивер: TBS 6983, TBS6522
- Антенна(ы): 2,20m, 3,70m
Спасибо strannik,
надеюсь, я к этому быстро привыкну.
- milan58
- Антенна(ы): Triax 110
Выбрал этот спутник и частоты, которые я с трудом могу получить с помощью антенны 110 см.
Я был удивлен, что эта версия IQMonitor фиксирует частоту, которая прекрасно воспроизводится с MPC-BE x64.Мои первые впечатления Я был в восторге (одушевљен).
Спасибо за новую версию и желаю вам здоровья.
Боты: Google [Bot]
