Octagon sx8 HD ONE MAGIC
sami noor
Непрочитанное сообщение sami noor »
OCTAGON SX8 HD ONE MAGIC
"Octagon SX8 Mini Full HD DVB-S2 Multistream FTA CA Satellite Receiver USB, Youtube, IPTV Black"
https://www.octagon-germany.eu/wp-conte ... 4x1024.jpg
With the Octagon SX8 HD One, you get an extremely low-cost, small yet powerful digital Full HD satellite receiver, ideal for installation in niches (behind the TV, for example). For this purpose, the longest side of the Octagon SX8 HD One measures just 11.3 centimeters and there is also a corresponding suspension and a four-digit IR display. This allows the receiver to hide in niches, while the display keeps you in complete control of the selected channels and so on. Pre-programmed for Astra 19.2 ° E & Türksat 42 ° E
Octagon SX8 Small all-rounder with pin-sharp picture quality
To receive your TV program, the Octagon SX8 HD One has a DVB-S2 tuner and a pin sharp resolution of 1080p. In addition to IPTV functionalities, there are other preinstalled apps including u.a. YouTube or the weather forecast ready. With these apps and the versatile connectivity options, you get a much more diverse entertainment experience than is possible with the pure TV reception. For example, the contents of external storage media, such as external storage media, can be accessed via the two USB 2.0 ports. Play USB sticks or external hard disks. Furthermore, the Octagon SX8 HD One has a connection for the power adapter (DC 12 V / 1 A), a connection for the IR display, an LNB input, an HDMI output as well as a jack and an RS232 connection. Together with the Conax card reader, multi-stream functionality, Unicable and DISEqC 1.0 / 1.1 / 1.2 USALS support, timeshift playback and recording as well as subtitles, teletext and EPG, the Octagon SX8 HD One becomes a small all-rounder with pin-sharp picture quality.
Key Features:
MPEG4 HD / SD, DVB-S2 Multistream Tuner
Multistream T2MI & Blindscan support without parameter input
YouTube, IPTV (m3u, m3u8) & more
card reader
2 x USB 2.0 ports
Recording, Playback & TimeShift (* optional)
External IR extender with 4-digit display
Characteristics:
Multistream & Blindscan
card reader
Recording & TimeShift (* optional)
WiFi (WLAN) support via USB ports
Unicable & FastScan Support
DiSEqC 1.0, 1.1, 1.2 and USALS Support
EPG Electronic Program Guide
High resolution OSD UI user interface
Subtitle & Teletext (Teletext) Support
Built-in media player function
0.5W standby
Dimensions (LxDxH) 113mm x 70mm x 20mm
Connections:
HD DVB-S2 tuner LNB input
HDMI output
Digital audio jack
RS232 socket
LED / IR (external display or IR infrared receiver) connection
2x USB 2.0 ports
AV audio video jack jack to RCA
DC-12V power supply
Delivery:
OCTAGON SX8 Sat Multistream Receiver
remote Control
2 x batteries
Operating instructions (German & English)
IR infrared receiver + four-digit display
Bracket for wall mounting
Power supply (power supply)
Presse
Abmessungen
Maße (LxTxH) 113mm x 70mm x 20mm
Gewicht
Anschlüsse
HDMI
USB
S/PDIF
Netzwerk
Externer IR Sensor
Stromversorgung
Stromaufnahme
Standby
System
Flash
Ram
CPU
Preis
UVP 29,90 €
https://www.octagon-germany.eu/produkte ... vb-s2/sx8/
sami noor
OCTAGON_SX8-HD-ONE_SW-CA_20180311 NEW SW - 06 04 2018
ALL_OCTAGON_SX8-HD-ONE_SW-CA_20180406.bin
APP_OCTAGON_SX8-HD-ONE_SW-CA_20180406.bin
SW UPDATE DEUTSCH
Datei ALL:
SW mit Senderliste und Multimedia Funktionen.
Vorhandene Senderliste und Einstellungen werden gelöscht!
Menü - Systemeinstellung - Firmware aktualisieren - OK Taste
USB-Aktualisierung - Abschnitt:
ALLES (Vorhandene Senderliste und Einstellungen werden gelöscht)
APP (Senderliste und Einstellungen werden beibehalten)
Dateipfad - OK Taste: SW Datei auswählen - OK Taste
Anfangen - OK Taste
Installation startet (Dauer ca. 2min.)
Datei APP:
SW ohne Senderliste und Multimedia Funktionen.
Vorhandene Senderliste und Einstellungen werden NICHT gelöscht!
Anfangen - OK Taste
SW BACKUP DEUTSCH
Software, Senderliste und Einstellungen können auf USB Medium gespeichert werden!
Erweiterungs Typ: Dump (Backup) auswählen (mit rechts / links Taste)
Dateipfad - OK Taste - USB wählen mit OK Taste (/mnt/usb01/02)
Anfangen - OK Taste
Backup wird auf USB gespeichert (Dauer ca. 2min.)
SW UPDATE ENGLISH
File ALL:
SW with inside Channel list and Multimedia functions
Existing Channel list and User Setups will be delete!
Menu - System Settings - Software Upgrade - OK Button
USB Upgrade - Section:
ALL (Channel list and User Setups will be delete)
APP (Channel list and USer Setups will be keep)
File Path - OK Button: Select SW file - OK Button
Start - OK Button
Installation start up (Takes arround 2min. Time)
File APP:
SW without Channel list and Multimedia functions
Existing Channel list and User Setups will be keep!
Start - OK Button
SW BACKUP ENGLISH
Software, Channel list and User Setups can save to USB storage!
Upgrade Type: Select Dump (Backup) (with right / left Button)
File Path - OK Button - Select USB with OK Button (/mnt/usb01/02)
Start - OK Button
Backup (Dump) start save to USB storage (Takes arround 2min. Time)
SW UPDATE TÜRKISH
Dosya ALL:
Kanal Listeli ve Multimedya özellikli yazilim
Kanal listeniz ve ayarlariniz silinir!
Menü - Ayarlar - Yükseltme - OK Tusu
USB`den Güncelleme - Bölüm:
Tümü (Kanal listeniz ve ayarlariniz silinir)
Uygulama (Kanal listeniz ve ayarlariniz silinmez)
Dosya Yolu - OK Tusu: Yazilimi secin - OK Tusu
Baslat - OK Tusu
Yükleme baslar (Süre: 2 dakika)
Dosya APP:
Kanal Listesiz ve Multimedya özelliksiz yazilim
Kanal listeniz ve ayarlariniz silininmez!
Baslat - OK Tusu
SW BACKUP DEUTSCH
Yazilim, Kanal Listesi ve Ayarlarinizi USB`ye yedekliyebilirsiniz!
Güncelleme Tipi: Dump (Backup) secin (sag/ sol Tusu)
Dosya Yolu - OK Tusu - OK Tusu ile USB secin (/mnt/usb01/02)
Baslat - OK Tusu
Dump (Backupunuz) USB ye yedeklenir (Süre: 2 dakika)
SW Änderungen / Changes / Degisiklikler
English:
- Subtitle and Teletext problem solved
German:
- Videotext und Untertitel ANzeige verbessert
Turkish:
- Videotext ve Alt Yazi iyilestirildi
CAS Menu Aktivierung /Activation
Menü - Systemeinstellung: PIN 6363 --> CA Setting (unten)
Menu - System Settings: PIN 6363 --> CA Setting (Bottom)
MENU PIN
--> Default PIN: 0000
--> Master Passwort: 8765
06/04/2018
http://www.mediafire.com/file/a8teco985 ... 282%29.rar
sofitt
Благодарил (а): 88 раз
Непрочитанное сообщение sofitt »
О! Оказывается админы Octagon (или близкие к ним, это вопрос терминологии наконец заметили и наш ресурс)
Как никак, но приятно.
Может больше прислушаются к особенностям СНГ рынка.
sami noor
OCTAGON_SX8-HD-ONE_SW-CA_20180517 NEW SW - 17 05 2018
ALL_OCTAGON_SX8-HD-ONE_SW-CA_20180517.bin
APP_OCTAGON_SX8-HD-ONE_SW-CA_20180517.bin
- Обновление SDK - Версия 1.8.4
- Добавлена функция XTREAM TV IPTV V2
- Проблема с телетекстом исправлена (Hotbird 13 ° E Polski)
- Добавлен автозапуск для IPTV:
- Меню - Системные настройки - Настройка экранного меню:
- Питание включено: DVB (SAT) / IPTV
- Добавлена функция импорта IPTV-импорта:
- Меню - Утилита - IPTV / CINEMA: Зеленая кнопка - Импортировать ссылку
- Улучшены языки клавиатуры
- Обновление драйвера WLAN WiFi
- Добавлена поддержка Flash EON
- добавлена аутентификация USB
- Astra 19.2 ° E & Türksat 42 ° E TP Обновление базы данных
SW UPDATE
Файл ALL:
SW со встроенным списком каналов и мультимедийными функциями
Существующий список каналов и пользовательские настройки будут удалены!
Меню - Настройки системы - Обновление программного обеспечения - Кнопка OK
Обновление USB - Раздел:
ВСЕ (список каналов и пользовательские настройки будут удалены)
APP (список каналов и настройки USER будут сохранены)
Путь к файлу - кнопка OK: выберите файл SW - кнопка OK
Пуск - кнопка ОК
Начало установки (занимает около 2 мин. Времени)
SW BACKUP
Программное обеспечение, список каналов и пользовательские настройки могут сохраняться на USB-накопителе!
Тип обновления: выберите Дамп (резервное копирование) (с правой / левой кнопкой)
Путь к файлу - кнопка OK - выберите USB с кнопкой OK (/ mnt / usb01 / 02)
Пуск - кнопка ОК
Резервное копирование (Dump) начинается с сохранения на USB-накопителе (занимает около 2 мин. Времени)
Активация / активация меню CAS
Меню - Настройка системы: PIN 6363 -> Настройка CA (внизу)
Меню - Системные настройки: PIN 6363 -> Настройка CA (снизу)
English:
- SDK upgrade - Version 1.8.4
- XTREAM TV IPTV V2 function added
- Teletext Problem fixed (Hotbird 13°E Polski)
- Autostart for IPTV added:
- Menu - System Settings - OSD Setting:
- Power On Play: DVB (SAT) / IPTV
- IPTV Import Link function added:
- Menu - Utility - IPTV/CINEMA: Green Button - Import Link
- Keyboard Languages improved
- WLAN WiFi driver upgrade
- EON Flash Support added
- USB authentication added
- Astra 19.2°E & Türksat 42°E TP Database upgrade
German:
- SDK aktualisiert - Version 1.8.4
- XTREAM TV IPTV V2 Funktion eingebaut
- Teletext Problem behoben (Hotbird 13°E)
- Autostart für IPTV eigebaut:
- Menü - Systemeinstellung - OSD Einstellung:
- IPTV Import Link Funktion eingebaut:
- Menü - Tools - IPTV/CINEMA: Grüne Taste - Import Link
- Tastatur Eingabe Layout verbessert
- WLAN WiFi Treiber aktualisiert
- EON Flash Support eingebaut
- USB Authentifikation eingebaut
- Astra 19.2°E & Türksat 42°E TP Datenbank aktualisiert
Turkish:
- SDK güncellendi - Versiyon 1.8.4
- XTREAM TV IPTV V2 özelligi eklendi
- Teletext hatasi giderildi (Hotbird 13°E)
- IPTV icin Oto start özelligi eklendi:
- Menü - Ayarlar - Menü Ayarlari:
- IPTV Import Link özelligi eklendi:
- Menü - Sistem Ayarlari - IPTV/CINEMA: Yesil Tus - Import Link
- Klavye dil destekleri güncellendi
- WLAN WiFi driver güncellendi
- EON Flash destegi eklendi
- USB dogrulama özelligi eklendi
- Astra 19.2°E & Türksat 42°E TP Databank güncellendi
SW UPDATE DEUTSCH
Datei ALL:
Anfangen - OK Taste
Datei APP:
Anfangen - OK Taste
SW BACKUP DEUTSCH
Anfangen - OK Taste
SW UPDATE ENGLISH
File ALL:
Start - OK Button
File APP:
Start - OK Button
SW BACKUP ENGLISH
Start - OK Button
SW UPDATE TÜRKISH
Dosya ALL:
Baslat - OK Tusu
Dosya APP:
Baslat - OK Tusu
SW BACKUP DEUTSCH
Baslat - OK Tusu
MENU PIN
17/05/2018
http://www.mediafire.com/file/2pl2ardee ... 180517.rar
sami noor
OCTAGON_SX8-HD-ONE_SW-CA_20180601 NEW SW - 01 06 2018
ALL_OCTAGON_SX8-HD-ONE_SW-CA_20180601.bin
APP_OCTAGON_SX8-HD-ONE_SW-CA_20180601.bin
SW изменения/ Änderungen / Changes / Degisiklikler
 изменения
Английский:
- Проблема с записью таймера из режима ожидания решена
- Примечание: нет поддержки записи многоканальных каналов!
- Обновление базы данных спутников и транспондеров
- Автозапуск для XTREAM TV IPTV добавлен:
- Power On Play: DVB (SAT) / IPTV / XTREAM
- улучшено IPTV IPTV XTREAM
- Добавлена ​​функция импорта IPTV-импорта: (iptv_server.xml)
SW UPDATE
Файл ALL:
Пуск - кнопка ОК
Файл APP:
SW без списка каналов и мультимедийных функций
Существующий список каналов и пользовательские настройки будут сохранены!
Пуск - кнопка ОК
SW BACKUP
Пуск - кнопка ОК
English:
- Timer Recording Problem from Standby solved
- Note: No Recording Support for Multistream channels!
- Satellite and Transponder Database upgrade
- Autostart for XTREAM TV IPTV added:
- XTREAM TV IPTV improved
- IPTV Import Link function added: (iptv_server.xml)
German:
- Timer Aufnahmen Problem vom Standby behoben
- Hinweis: Keine Multistream Aufnahmen möglich!
- Satelliten und Transponder Daten aktualisiert
- Xtream Autostart Funktion eingebaut:
- XTREAM TV IPTV verbessert
- XML IPTV Server Funktion eingebaut: (iptv_server.xml)
Turkish:
- Standbydan zaman ayarli kayit hatasi giderildi
- Bilgi: Multistreamde kayit destegi yoktur!
- Uydu ve Transponder`ler güncellendi
- XTREAM TV icin Oto start özelligi eklendi:
- XTREAM TV IPTV özelligi iyilestirildi
- IPTV Server Import Link özelligi eklendi: (iptv_server.xml)
SW UPDATE DEUTSCH
Datei ALL:
Anfangen - OK Taste
Datei APP:
Anfangen - OK Taste
SW BACKUP DEUTSCH
Anfangen - OK Taste
SW UPDATE ENGLISH
File ALL:
Start - OK Button
File APP:
Start - OK Button
SW BACKUP ENGLISH
Start - OK Button
SW UPDATE TÜRKISH
Dosya ALL:
Baslat - OK Tusu
Dosya APP:
Baslat - OK Tusu
SW BACKUP DEUTSCH
Baslat - OK Tusu
MENU PIN
01/06/2018
http://www.mediafire.com/file/dsrkf6v44 ... 180601.rar
