TBS6903-X
TBS6903-X
Да, это будет правильный выбор :good:
satesco
Антенна(ы): 150cm
Благодарил (а): 423 раза
TBS6903-X
Ivan66 писал(а): 10 ноя 2019, 10:03 как я понял для поиска фидов сейчас лучше взять TBS 6903. на али https://ru.aliexpress.com/i/32811089189.html продают оригинальные или лучше взять на оф. сайте?
Of all dvbs2 cards,the best for feeds receptions is tbs6903.But you have to keep in mind that this card does not have the S2X extension.With this option,you have to choose between two demodulator brands, the STM and Silicon Lab,each with its advantages and disadvantages.
Tbs6903X,6909x has demod from STMicroelectronics,and 6522,6590, etc has a Silicon demo.Below the similarities and the difference between 6903X and 6909X by the characteristics that each one has.
VictorLS
Благодарил (а): 261 раз
TBS6903-X
satesco писал(а): 10 ноя 2019, 13:46between two demodulator brands, the STM and Silicon Lab,each with its advantages and disadvantages.
It's some offtop here but can you briefly describe advantages (not from provided picture) Silicon Lab demodulator over STM in subj (and disadvantage STM compared to Silicon Lab)?
For example, as I know STM can lock 'continuous' streams but Silicon Lab can't...
satesco
Антенна(ы): 150cm
TBS6903-X
I'm sorry,@VictorLS,but I no longer have the energy and interest to describe the advantages and disadvantages of these demos.The only thing I can do is send you to my texts about two cards with this demod on the forum where I posted them.Again I'm sorry they're not in your language.But even approximately,they can be translated with Google translator.
About the Silicon demod for tbs6522 here and about tbs6590 here .
About SMT demod for 6903X, here
Unfortunately,the pictures illustrating the texts have disappeared because of the host.
Mikroniks2020
Антенна(ы): 1,8 супрал
TBS6903-X
Тогда просто корпус хорошо продуваемый использовать с вертушками 2х200.
VictorLS
TBS6903-X
Видимо тепловыделение оказалось меньше, чем ожидалось и от вентилятора решили отказаться, заменив радиатор
https://www.tbsdtv.com/products/tbs6903 ... -card.html
Mikroniks2020
TBS6903-X
Скажите TBS6903-X лучше ресивера GI Ultimo 4k? Стоит чуть дешевле его, стоит карта своих денег 30тонн?
Ну наверно не совсем правильный вопрос возможности больше чем у ресивера у любой и менее дорогой карты с двумя тюнерами и более.
Как бы комп и карта это в любом случае мощнее реса итд. Вопрос стоит ли она своих денег? Что бы столько платить.
femi
Благодарил (а): 39 раз
TBS6903-X
Могу посоветовать только TBS6903-X. Сканирование одного только спутника может занять несколько часов, а с TBS6903 или TBS6908 это можно сделать за несколько минут.
Он все еще в моем компьютере, но это заняло у меня последние нервы.
Satesco может подтвердить это наверняка.
I can only recommend TBS6903-X. Scanning a satellite alone can take several hours, and with a TBS6903 or TBS6908 it can be done in a few minutes.
It's still on my computer, but it took my last nerves.
Satesco can confirm this for sure.
satesco
Антенна(ы): 150cm
TBS6903-X
Mikroniks2020 писал(а): 24 июн 2021, 17:54 Скажите TBS6903-X лучше ресивера GI Ultimo 4k? Стоит чуть дешевле его, стоит карта своих денег 30тонн?
If you are a simple TV consumer and you also want to receive weak signals,then you can buy the tbs6903 card.It is the best professional card for search speed and for many other things.But you should know,that tbs6903 does not know the S2X extension.
Instead,the tbs6903x is at another level of performance,but due to some ultra fast search limitations,scanning takes longer, as @Femi said.
The comparison between a receiver,even with the latest technology implemented,and a dvb card should be made by the one who wants to buy.A receiver is generally limited by the support that a manufacturer provides,while a card has a diverse and continuous support by the developers of their applications.
I'm not sure I'm right in all cases,but if I'm theoretically right,then choosing the device you want is self-evident.
Mikroniks2020
TBS6903-X
Так а TBS6903-X это только если весь спутник сканировать часами будет сканировать? А если определенный диапазон скажем от 11000 до 11700 не долго же. И почему долго сканирует, очень подробно все перебирает? А чувствительность лучше TBS6903 или такая же?
Что посоветуете из S2 моделей? Нужно максимальную чувствительность прежде всего, так то я фиды смотрю частоты за ранее примерно знаю в каком диапазоне искать или публикуют, сканировать постоянно смысла нет. S2X его практически нет вообше, три канала на 33гр и все..
