Приём и обсуждение 25.8°E - Es’hail 2 в Ku диапазоне
Благодарил (а): 486 раз
Hello Peon,
that would be an explanation. So far, however, has only occurred in one LNB. I've already checked 4 others.
regards
Ресивер: TBS cards
Благодарил (а): 387 раз
Move the antenna away from the satellite. The 10600MHz signal will still be there.
*jokingly*
milan58
Антенна(ы): Triax 110
Благодарил (а): 630 раз
Мистика решается с помощью LNB циркуляр! :lol:
Приём и обсуждение 25.8° East Es'hail 2 (ATV)
Принял 3 частоты одновременно
Благодарил (а): 806 раз
с антенной 1,20 тоже работает
AMSAT France
10730 H 30000 3/4 "Es'hailsat Packet" Mena Beam
Из рассылки Hearsat. Спутник с другой стороны.
Офтопик
Hi
I have joined the HearSat mailing list primarily to learn how to build the
necessary kit to use Es-hail-2. I have a 90cm offset dish left over from
the time when I experimented with satellite TV together with a polar mount.
I am intending to have a go at building a dual band patch antenna which
looks relatively straight forward apart from the testing and adjustment.
Generally I am looking for “getting started” advice so that I can decide
what equipment I need.
Rgds
David M0TGC
Lyme Regis, Dorset
David,
I suggest you take a look at the BATC Wiki. For receiving a PLL LNB is
better than a DRO type, and likely essential for SSB reception. Folk have
locked the LNB to a GPSDO to eliminate drift and provide accurate
calibration. I've received SSB with a PLL LNB and a "37 cm camping
antenna", so 90 cm should be no problem. I used the pass-through output of
a receiver (TBS5925) fed to an Airspy running on ~700 MHz, but you could use
the Web receiver to start with.
I've not done anything with transmission, but likely I would try to run an
SDR (Lime, Pluto etc.) and amplify it up.
73,
David GM8ARV Edinburgh
SatSignal Software - Quality software for you
Web: http://www.satsignal.eu
Email: david-taylor@blueyonder.co.uk
Twitter: @gm8arv
______________________________________________________________
Home: http://mailman.qth.net/mailman/listinfo/hearsat
Help: http://mailman.qth.net/mmfaq.htm
Post: mailto:HearSat@mailman.qth.net
10496,5 H 1000
sr 1000 DVB-S2 QPSK2 2/3
PE1ASH MIJDRECHT
