Приём и обсуждение 97.2°E - GSAT 9 в Ku диапазоне
Сегодня попробовал принять новый спутник с новой орбитальной позиции 97.3°E
Принял сигнал на антенну 1.4м так как полярный подвес имеет возможность такой наклон, Супрал 2.0 к сожалению имеет поворот до 96.5°E
- satesco
- Антенна(ы): 150cm
Приём и обсуждение 97.3°E - GSAT 9 в Ku диапазоне
Pretty good signal on G-Sat 9 at 97.2E,but for a secure reception,you'd need an antenna bigger than mine,150cm.
Here's what I got from this bird in my area:
Это очень удивительно Вы находитесь дальше меня от луча, а сигнал у вас выше
- satesco
- Антенна(ы): 150cm
Thanks a lot @Wellikan I'm surprised by the signal,too,but I have to add it's fluctuating at elevation above 2°.I didn't think I could receive it.I think the signal's coming from the Afghan beam,not the Indian,because the tv package at 11492 V is Afghan.
The Madani TV feed may be on the Indian spot,but I'm not sure.
I must admit that I did not think that I will receive this satellite,because I thought it is not possible with my small antenna but from time to time I came across a weak signal at 11655 V and watched how it manifests.I could see it grow and then it gets weak.From that moment on,I monitored the signal and scanned when the signal became stronger,and at that point other transponders appeared on the spectrum.That's the only way I discovered 11492 V too.
I'm surprised you don't get this beam because you're closer,in eastern Ukraine,if I'm not mistaken.Maybe you should do what I did,stay with the antenna longer at this position and,who knows,maybe you're lucky enough to catch it.I'm convinced that eventually you'll get 11492 V,because,although fluctuating,it can reach over 9db.I managed to lock it when the signal exceeded 9dB,because it has 8PSK mode and fec 5/6,parameters not too friendly for our area compared to the beam.
I keep my fingers crossed you succeed.
I have to thank you for the map of the G-Sat 9 satellite posted in the first topic.I don't know where you found it,because I searched on net and forums and I couldn't find the map you posted.The one at FlySat is for India only.
I have a request,can I post this map on the Satellite Community forum?Thanks.
Kind regards
Kind regards
Я наблюдал за этим спутником 4 дня
Утром перед выходом на работу, в обеденное время и целый вечер иногда до поздней ночи, но сигнал так и не появился
- satesco
- Антенна(ы): 150cm
I'm sorry you haven't made it by now. But I still think you'll be able to lock the 11492 V transponder, because I'm going to show you how the signal increases in my area to 12dB!!!,after which it drops.
Try in the morning and noon,because then it's the strongest signal,at least in my area.
We have to keep in mind that the signal comes in waves, fluctuating continuously,as it grows to 12dB, it keeps around 4dB or 6dB for a long time,after which falls.Unfortunately the fluctuation does not manifest itself according to a pattern,as at other positions with low elevations,say,100.5E.
But you better watch the videos in the link that I recorded,maybe help you draw conclusions about what you need to do.
You've got more antennas of different sizes,try one bigger than 1.40m.I'm convinced you can finally get 11492 V, maybe even feeds.
Regards
http://www.mediafire.com/file/6nxrzkeog ... k.zip/file
Отправлено спустя 9 часов 11 минут 32 секунды:
I've been monitoring the signal on 11492 V for a long time and now I can say that it manifests the same throughout the day.The only condition that it can be locked is that the weather is favorable,without rain.
Here's how the signal is at 22:00,and because it's strong I've managed to receive the Afghan package both with DM920 and the AltDVB player.
Regards
Начал следить за спутником GSAT 9 и заметил следующие несоответствия:
Направив антенну по максимальному сигналу транспондера 11493 V 2600 5/6 DVB-S2/8PSK появляются частоты со спутника 98°E - ChinaSat 11, но частота 11232 V 4444 5/6 DVB-S2/8PSK отсутствует.
Стоит повернуть антенну западнее появляется транспондер 11232 V 4444 5/6 DVB-S2/8PSK, а с ним и частоты со спутника 96.5°E - Express AM33 и при этом пропадает 11493 V 2600 5/6 DVB-S2/8PSK
- satesco
- Антенна(ы): 150cm
Interestingly,@Wellikan,11232 V is at 97.3 E,told me an enthusiast on an indian forum.I don't know why it is at 98.0E? I have to admit,I wish I could see a signal on this transponder in my area.The package is from Bhutan,in the eastern part of Pakistan.
What antenna do you use on 97.3 E and 98.0 E?It's very hard for a small antenna to completely separate positions so close,not even one degree,especially since the signal comes from remote spots.I'm just surprised you can't lock 11492 V and at the same time you get a signal from the Indian beam?Weird.
Regards
Regards
Проверь пожалуйста новую частоту которую я поймал: 11531 V 1119 3/4 DVB-S2/8PSK
Отправлено спустя 36 минут 43 секунды:
Отбой, это был FEED
Отправлено спустя 3 часа 12 минут :
Поймал ещё один FEED на частоте 11533 V 1279 3/4 DVB-S2/8PSK
Отбой, это был FEED
- satesco
- Антенна(ы): 150cm
The signal on 11531 V does not increase more than 4~5dB,at best case.And looks like it's coming from the India spot.If it's true,then I have no chance of lock it(?!).Who knows.
Regards
Regards
