Тестирование 96.5°E - Express 103 в Ku диапазоне
Тестирование спутника Express 103 в позиции 96.5°E :Yahoo!:
12573 H и 12573 V
satesco
Антенна(ы): 150cm
Благодарил (а): 423 раза
Congratulations,@Wellikan.As usual you give us good news :good: I'm waiting for you to lock a signal with the parameters at this frequency or another.
(I hope it's not a terrestrial frequency that's been popping up more and more in the Ku-band in recent years.The fact that the signal appears on every polarity makes me wonder if it is one of this kind of interference.I hope not,because this interference is very misleading.On my spectrum is coming up more and more often such interference-LTE,Wi-Max,and 5G).
On the other hand,I didn't know Express-AM33 was gonna use the upper band in the ku-band(?!).
Тест ушёл, и спектр выглядит сейчас :cry:
Снова тестируют :good:
satesco
Антенна(ы): 150cm
I wish I wasn't right,@Wellikan,but apparently,I think the same signal on almost the same frequency is more like interference than a satellite signal?! It looks almost like on my spectrum but on another frequency.I'm not surprised at that,because the elevation in my area for this position is 3.19°.Only a strong signal could eliminate as much noise as possible from the useful signal.
Of course,I'd like the signal and propagation on Express 103 to be more generous in my area than AM33.Anyway,you have a chance of picking up this new satellite because you're closer to the satellite's coverage area.
I guess you don't mind if I post the satellite map here for the Ku and C bands.
I look forward to your reports from 96.5 E :-)
satesco
Антенна(ы): 150cm
I hope I'm not wrong,I think Express 103 became operational at 96.5E;all transponders have been moved from Express-AM33.
Unexpectedly good signal if I take into account that before I did not catch any transponder in the Ku band in my area :good:
BandEross
3
Ресивер: Formuler 4K S Turbo
Благодарил (а): 56 раз
Только этот Транспондер у себя принял .. вот сомневаюсь .. имеет он вообще отношение к 96,5°Е :unknown:
Penza1989
3
Ресивер: HD BOX S500 CI PRO
Непрочитанное сообщение Penza1989 »
BandEross,а Вы в каком регионе проживаете?
BandEross
3
Penza1989 писал(а): 15 апр 2021, 12:21 BandEross,а Вы в каком регионе проживаете?
Россия Приморский край Уссурийск
satesco
Антенна(ы): 150cm
Maybe @Wellikan or other enthusiasts will try to lock the signal on a few transponders(all new) in the upper band. I can't because of the small antenna :wall: , but also because of the large fluctuation at this low elevation.
And an update from my area from Express-103 :good:
12509 V,2859,4/5,32APSK-unlock,
12514 V,6294,4/5,32APSK-unlock,
12521 V,2600,4/5,32APSK-unlock,
12523 V,867,4/5,32APSK-unlock.
