5g interface c band spectrum signals
- Sat hunter
- 3
- Ресивер: Strong 4957
- Антенна(ы): 240 cm , 180 cm
5g and anti Wimax interface c band spectrum reception in my location
see here spectrum and signal unstable
using Gulfstar 17K is the best for me for fringe reception and weak transponders but now not working as you see
some companies like Asiasat and norsat provide some solutions by producing filters to protect signals from 5g and anti WIMAX interfacing but still are expensive solutions
specifications of Asiasat filter
comparing Asiasat filter with other filters in the quality of signals when filter protect signals from 5g and Anti-Wimax interface
for more information about Asiasat filter
https://www.asiasat.com/innovations/5g/5Gfilter
norsat filter
https://www.norsat.com/satellite-compon ... terference
AV com filter
its cost 620$
https://www.avcomm.com.au/shop/lnbs/c-b ... ss-filter/
https://www.avcomm.com.au/c-band-and-5g-interference/
norsat filter
AV com filter
its cost 620$
Antenna : (240 cm - 180 cm - 120 cm - 90 cm ) Tuners : ( TBS5520SE - Strong 4957 - DreamMax S2X - Tiger T8 V2 - Octagon Sf8008 combo ) Meter : ( DrHD 1000 combo) Reception : ( KU and C band ) location : ( Oman )
Видел варианты подешевле.
- Peon
- Ресивер: TBS cards
If the interference is directly at the specified frequency of 3935 MHz, then the filters you state will not help. They only filter spectrum outside the 3.7-4.2GHz band. When the interference is in the band of transient frequencies, the interference itself passes. From my experience, I know that an ADE antenna will help. Suppresses interference by up to 15-20dB.
Есть варианты фильтра подешевле, но надо разговаривать и детальные фото
https://www.avito.ru/habarovsk/audio_i_ ... 1904185233
Ты учитывай географическое положение человека который создал новую тему. Где он, а где ваше предложение
У меня и на прошлых типах G проблемы с наводкой из-за вышки под носом.
Думаю,и не только у меня
- Dakev
- 3
- Ресивер: EDISION OS Mio 4k, Openbox AS4K
- Антенна(ы): C band: 2x220см, 150см
Привет из Болгарии! Я нов тут, ползуюс три прямофокусних антен на ц диапазон - 2х220см и одна 150. Месец два назад установили вишка для сотових 5G недалеко от меня. Все от 3630 до 3660 невозможно смотрит. За сожаление на соседни частот тоже появляются помехи. Недавно я заказаль фланцевых конверторами и филтри для них. Вчера я получил их и надеюс скорее что могу попробую как они на самом деле.
https://ibb.co/LzgndQX
https://ibb.co/5TmVjQ3
https://ibb.co/NxNPT3B
https://ibb.co/Ry19PbG
https://ibb.co/PjXDTxx
https://imgbb.com/Vmkx3P7
- albert84
Very beautiful, stylish things and incredibly expensive, it is scary to even imagine the final purchase price. I hope this will give a result. One thing I don't understand. but if the interference is directly at 3630-3660, then the filter will cut off these frequencies, that is, reception will remain impossible for transponders within 3630-3660 ? What, then, is the point of using a filter ?
- Dakev
- 3
Дело в том, чтобы уберечь от помех соседние частоты, которые иногда начинают глючить от высокой напряженности поля. Позже этом месяце я попробую сделат второй отражатель для ADE Omnidirectional Dual Reflector антена, ето по словам коллег надо поможеть принят сигнал со спутника на которой работает наземная несущая частота.
