Транспондерные новости 31.5°W - Intelsat 25
TM 2 (ORTM 2) вернулся на 12344 V 2121 FEC 7/8, DVB-S/MPEG-2, открыто
Доброе утро.
С 13 апреля на этом спутнике действует новая частота. 12335 V 6427 7/8
Он заменит две старые частоты.
Старые частоты будут отключены 19 апреля в полночь.
Из Баварии новая частота немного слабее старых.
это ограничение на получение.
- flie
- Ресивер: TBS5927
unfortunately signal is barely seeing from here
- satesco
- 10
- Антенна(ы): 150cm
@flie,you do not need to scan the entire satellite band.It would be good to look at a satellite list,let's say,FlySat,and see which band is using that satellite.Only a few positions(19.2E,13.0E,0.8/1W) are used the whole Ku-band.With Crazyscan you have the possibility to limit the bandwidth of the scanning according to your desire.If screenshots are only for you,there is no problem,but if you post for others,it is advisable to do what I told you above.Most of us are interested in the frequencies that you found.The easier we read the spectrum,the signal found,so much the better.
regards
regards
- flie
- Ресивер: TBS5927
thank you very much satesco , malval450 talk about this too
my scan now
my scan now
- dreamsat
- 10
- Ресивер: TBS 6983, TBS6522
- Антенна(ы): 2,20m, 3,70m
12334 V 6426 7/8 New " Energy TV "
- dreamsat
- 10
Carrier on 12319 V 6500 . I have to try again with 3.7m.
- dreamsat
- 10
now is a Lock at 12319 V 6500 7/8
- dreamsat
- 10
two new transponder with unknow modulation
regards drteamsat
regards drteamsat
