Собственно энергетика 56°E - Express AT1 европейского луча мощная и идет с отличным запасом в мультифиде на круговой конвертор (10750) -на антенне 110см при центре 60Е:
Signal locked on the Wide beam with lnb linear,of course that transponders appear on both polarities.I think 12034 L/H ,12054 R/V,12073 L/H,12092 R/V couldn't be locked due to interference on the band although the signal is strong.Who can show the spectrum in this part of the band?Thanks
Thanks for the spectrum.So the same situation with your antenna with the unlock signal on those transponders.Until proved to the contrary or a technical explanation is valid,I keep thinking that the four unlocked transponders are mutually influencing.
I'm still curious if using a lnb circular gives the same result or lock the four transponders?
Regards
