Благодарил (а): 806 раз
Привет странник :drinks:
Я только что провел то же исследование, что и вы, на 10 ° восточной долготы с версией 2303.
Результаты тоже очень хорошие. :Yahoo!:
Я, очевидно, лучше, чем вы, для приема и с большей антенной.
Я надеюсь, что это будет полезно для вас.
хороший день :friends:
Stephan94
flie
Ресивер: TBS5927
Благодарил (а): 246 раз
very good result Stephan :good:
I wanted to make Crazyscan works with TBS6903X but without success, I don't know how it works with Satesco & peon Изображение ?!
I think Strannik has made the right decision when making IQmonitor can work even with cards that don't support RF scanning :good: :drinks:
a simple test with N=180x2 was made in 21.6°E with both version IQmonitor 2.3.0.0 & 2.3.0.3 :good: :
finally I discover that Feed-Report was always working in back , but I can't see it! because my PC resolution (1366x768) :facepalm: ! when I use an other resolution in an other PC (1280x960) I see Feed-Report in my screen corner ! so I pull it out :-D ...sorry about that :oops: .
the only problem I Have now is "set-filers" is very slow when parser via Ts-file throw other programs like (TranEdit...VLC...etc) ,because I use a Hard disk USB 2.0 ! with wery low volume (only 16 GB!) :-o ....I forget that transferring any files with USB 2.0 is very slow ! :facepalm: sorry about that one too :oops:
Added in 39 minutes 31 seconds:
I can use only IQmonitor so I don't know what are these transponders ? Generic-stream or Encapsulated ??? :unknown:
ACM/VCM :unknown: ???
10730 V 45000 Qpsk2 4/5 MIS{1} ACM/VCM???
10918 V 45000 Qpsk2 4/5 MIS{1} ACM/VCM???
11109 V 1868 Qpsk2X 13/18 MIS{0} ACM/VCM???
Added in 46 minutes 49 seconds:
yes they are Transport-stream ACM/VCM MIS! can be found with TBS5521 too !
apparently TBS5521 multiply the number of GS-Transponders !!! :facepalm:
with TBS5927 the only not found is 11109 V 1868 Qpsk2X .
Already reported as Transport Multi-stream with IQmonitor-Feed report But I didn't read it ! :facepalm:
Ресивер: TBS cards
Благодарил (а): 387 раз
flie писал(а): 14 ноя 2019, 18:29
@flie
CrazyScan 10216 was 4 versions. You must use the one from 7.11.2018 and others. :good:
Последний раз редактировалось Peon 15 ноя 2019, 18:07, всего редактировалось 1 раз.
@flie
Очень хороший тест, я вас поздравляю! :good:
В нём даже есть ответ на ваши вопросы:
flie писал(а): 14 ноя 2019, 18:29 I can use only IQmonitor so I don't know what are these transponders ? Generic-stream or Encapsulated ??? :unknown:
Просто надо внимательно почитать полученную вами сводную таблицу транспондеров: ----> Таблица транспондеров
Что касается "мультиплексирования" транспондеров, так это баг в CrazyScan - blindscan не может "отцепиться" от "сильного" транспондера.
В IQmonitor была аналогичная проблема (ведь используется один и тот же StreamReader уважаемого Crazycat`а) :pardon:
:friends:
Ресивер: TBS cards
strannik,
Спасибо за новую версию IQmonitor. Я с нетерпением жду тестирования. :Yahoo!:
У меня нет времени сейчас. :mad:
Peon писал(а): 16 ноя 2019, 08:53 strannik,
Надеюсь, что ваши проблемы будут успешно решены, время появится, и вы воспользуетесь IQmonitor 2304.
Здоровья и успехов! :friends:
Спасибо большое Strannik :friends:
хорошие выходные
Stephan :drinks:
Added in 17 minutes 38 seconds:
stephan94 писал(а): 16 ноя 2019, 09:40 Спасибо большое Strannik :friends:
хорошие выходные
на версии 2304 сигнальные полосы отсутствуют в левом нижнем углу. :sorry:
Stephan :drinks:
Added in 59 minutes 20 seconds:
Первые тесты убедительны.
идеальный результат. :Yahoo!: :good:
Сегодня отключил RFScan при индикации частоты настройки.
Протестировал программу на Жар-птице - результат был получен за 3мин. 11 сек на вертикальной поляризации,
где транспондеры плотно заполняют весь диапазон, и за 3 мин.44 сек на горизонтальной поляризации,
где есть несколько "пропусков" между транспондерами :good:
Благодарил (а): 486 раз
Спасибо strannik,
надеюсь, я к этому быстро привыкну. :good: :good:
milan58
Антенна(ы): Triax 110
Благодарил (а): 630 раз
Выбрал этот спутник и частоты, которые я с трудом могу получить с помощью антенны 110 см.
Я был удивлен, что эта версия IQMonitor фиксирует частоту, которая прекрасно воспроизводится с MPC-BE x64.Мои первые впечатления Я был в восторге (одушевљен).
Спасибо за новую версию и желаю вам здоровья.
