flie
Ресивер: TBS5927
Благодарил (а): 246 раз
this is time on Ka-band feed report works :Yahoo!:
no need to use the earlier version IQmonitor 2.3.0.0
A simple test on Ka-band with TBS6903X with Auto_SR (if I use manual SR from 100 to 50000 with TBS6903X it will take an extra unnecessary long time !)
with Crazyscan the Transponders need to be in the centre !!!
Added in 4 minutes 8 seconds:
Unlike the situation in Ku-band :unknown:
the DVB-S2X signal (19722R ) is not clear here on Ka-band with TBS5927
trying with (Auto SR 180x8,Manu SR 5000x8,Manu SR 10x1)
flie
Ресивер: TBS5927
the mysterious range 12500-12750H @3°W MENA beam
12550H68000 ! I think locked manually and very hard with IQmonitor :good:
flie
Ресивер: TBS5927
test even with extreme parameters N=5500X15 :-)
What can I say ... It was a great experience :cool:
regards :friends:
flie
flie
Ресивер: TBS5927
BlindScan works with TBS6930X without RF_scan or H.R.Spectra .! and its very fast ! :shock:
IQmonitor : 83 TPs in 156s s (V)+ 110 s (H) + 20 s (for drinking Tee or Coffee *jokingly* ) =only 286 s
Crazyscan : 87 TPs (H & V) in 31 s (FFTscan) + 1813 s (BLScan) = 1845 s !
IQmonitor is 6 time fast !!!
very impressive :Bravo:
sadly TBS6903X has problem with mixing Ku_low and Ku_high transponders :facepalm: :facepalm: :facepalm:
thank you very much Stannik for sharing with us your priceless program :drinks:
IQmonitor 2.4.0.1 is Already here : ;-)
https://filatov-yuri.livejournal.com/
https://workupload.com/file/eECNJGZPPCJ
Best regards :drinks:
flie
flie
Ресивер: TBS5927
My Utra-specrum @ 30°W...I still can see 11695 V 185 :good:
nickomaru
2
Ресивер: TBS6904SE
Антенна(ы): Supral 1.8.Supral 1.4 7e,10e,1W,3W
Непрочитанное сообщение nickomaru »
TBS 6904SE
BLScanEx() not supported !
CrazyCat
Благодарил (а): 36 раз
BLScan2 only supported for Montage demods.
nickomaru
2
Ресивер: TBS6904SE
CrazyCat писал(а): 18 окт 2021, 18:21 BLScan2 only supported for Montage demods.
жаль
CrazyCat
так BLScan2 просто летает :-D зачем вам "черепахий" BLScan ? :-)
nickomaru
2
Ресивер: TBS6904SE
CrazyCat писал(а): 18 окт 2021, 21:24 так BLScan2 просто летает :-D зачем вам "черепахий" BLScan ? :-)
похоже,мы говорим о разных вещах
У меня карта ТБС6904 S2X
Для нее уже есть какой то работающий анализатор?
