flie
Ресивер: TBS5927
Благодарил (а): 246 раз
We can even get a better time : ..spectrum in13seconds...Blindscan..in only. 24seconds! IQmonitor est incroyable ! %)
and about PAT table; I think I have a way to get better scream-shot :cool:
Последний раз редактировалось flie 12 дек 2018, 01:00, всего редактировалось 1 раз.
flie
Ресивер: TBS5927
very good scream-shots with VLC,4T2,TSReader. :Bravo:
IQmonitor scream-shots work well with 4T2 with TS.file or in streaming mode :Yahoo!:
I don't know how to make 4T2 Thumbnails smaller ? :Search:
any way my pc can't handle 4t2 in streaming mode with "video-Analysis" ! CPU usage 97% :facepalm:
flie
Ресивер: TBS5927
also better result with DVBInspector :drinks:
unfortunately my dish is in inclined with 0.5° :facepalm: I have to correct that :oops:
beam-pattern & Finetune are great :Yahoo!:
flie
Ресивер: TBS5927
Scream-shots work well also with multi stream channels :Bravo: you can see also "stream number" at top with the TP & his signal :good:
NB: some times PAT tabe can not load ! may be because ts.file not save well by "set filters" or Error parser when trying to "Get SID" :Search:
flie
Ресивер: TBS5927
The most important for me ;that I can see these strange constellation with IQmonitor too :Yahoo!:
thank you very much strannik for great program :Bravo:
and Thanks to all the members who help you develop IQmonitor :friends:
milan58
Антенна(ы): Triax 110
Благодарил (а): 630 раз
dreamsat писал(а): 11 дек 2018, 20:15 Привет strannik,
где я могу найти pcb-be64.exe
https://sourceforge.net/projects/mpcbe/files/
Ссылка на скачивание MPC-BE
Или скачайте инсталятор прямо с форума:
MPC-BE.1.5.2.x64-installer.zip
И снова о выборе программы для компьютерного анализа спутникового сигнала.
Сопоставляется программа IQmonitor с общепризнанной программой автора StreamReader`а уважаемого crazycat`а - CrazyScan с одинаковым шагом регистрации спектра - 6МГц
ИзображениеСпектр зарегистрирован программой CrazyScan за 5.3сек
Программа IQmonitor зарегистрировала спектр за 8сек:
Изображение"Лишние" 3сек ушли на обработку спектра.
Даже без коррекции неравномерности АЧХ второй спектр выигрывает по качеству у первого, а разница во времени без секундомера не заметна.
При слепом поиске CrazyScan затратила 124сек для нахождения 30 транспондеров (из 29 возможных ;-) ):
Программа IQmonitor на слепой поиск затратила всего 31сек (в 4 раза быстрее), что на полторы минуты меньше:
При этом определены параметры всех фактически присутствующих 29 транспондеров. Кроме Level,% может быть дополнительно
выведен запас по локу транспондера в dB. Для мультистримов выводится количество потоков, а для скремблированных транспондеров -
тип и код PLS.
На последний планшет программа IQmonitor вывела спектры с калибровкой (исключена неравномерность АЧХ системы
антенна - LNB - кабель снижения - тюнер РС карты ). Здесь преимущество качество спектра IQmonitor очевидно,
тем более, что полупрозрачная разметка транспондеров подчёркивает качество спектра, а не "забивает" рисунок как в CrazyScan.
Программа IQmonitor выполняет весь функционал CrazyScan, но делает это более качественно и быстро.
Кроме того, программа IQmonitor имеет расширенный список дополнительных функций, многие из которых уникальны :good:
flie
Ресивер: TBS5927
36°E Sub-Sahara African-beam ...spectrum & transponders list
with manual search for "no locked signals" . all "no locked signals" added automatically to the transponders list :good:
Сравнение программ при шаге регистрации спектров 1МГц - "точный" режим регистрации.
CrazyScan - регистрация спектров 185 сек:
Слепой поиск 101 транспондера без разметки несущей 117 сек:
Разметка несущей добавляет 2 сек, но качества результатов не добавляет:
Все SR занижены, до 7kS/s. Не определено ни одного точного значения SR.
IQmonitor - регистрация спектров 184 сек:
Слепой поиск с разметкой транспондеров выполнен за 61 сек - в два раза быстрее:
Все 101 транспондер с точным определением SR :good:
Слепой поиск выбранной частоты в CrazyScan:
Сравните с качеством констелляции и спектром, которые получены в IQmonitor:
Количество точек построения почти одинаковое ~15000
Отчёт о слепом поиске оформляется одним кликом по кнопке "ScreenShot":
Про лёгкость и разнообразие оформления отчётов напишу позже
Также позже напишу про информацию, которая есть на FeedReport, и которой нет в других программах.
Это крайне важно для DX-эров, которые вылавливают слабые сигналы, часто под порогом лока.
Следите за темой :-)
